Maximo 7.5 BIRT report direct print using __action=print
Hi All,
We have a requirement to direct print a label to a specific printer through Maximo
I am envisioning it to be BIRT report with required format. Is it possible to add parameters like __format and __action=print to the report design file so that when the report is deployed to Maximo it would take these as URL parameters and direct print the report
My question to the group is , would a Maximo end user be able to print the Maximo BIRT report directly with this report design file instead of using the Maximo Direct print functionality. Has anyone used __action=print parameter in the report design file to print the report
Any inputs on this will be very helpful
