Using parameters in views
Hello,
I need a little help with a query.
I have a 2 views and a select:
testCTE AS
select loc, parent, lochierarchyid, locationid
from lochierarchy
where loc=(select loc from workorder where workorder.wonum='44325333rfsrrhyvf') and locationid=(select locationid from workorder where wonum='44325333rfsrrhyvf')
UNION ALL
select lochierarchy.loc, lochierarchy.parent, lochierarchy.lochierarchyid, lochierarchy.locationid,
from lochierarchy
join testCTE on lochierarchy.loc = testCTE.parent where lochierarchy.locationid='INTERNATIONAL'
/* Another view here TEST2VIEW */
SELECT (select distinct  l.description from testCTE t1
left outer JOIN testCTE t2 on t1.parent=t2.loc left outer join
 locations l on l.loc=t1.loc
and l.locationid=t1.locationid
 where l.FIELD='YES') as Community, /* other fields */ from TEST2VIEW where TEST2VIEW.wonum='44325333rfsrrhyvf'
I know that i can define a parameter and connect it to  TEST2VIEW.wonum but if I try to give the same parameter in the first view it doesn't work. Can someone please help me?
