How to create progress bar using bar graph in BIRT
Hello Team,
I want to create progress bar ,
my scenario is that there are six phases in a project ,
show the status of all phases in one bar,
each phase has is own color,
phases value increasing on count suppose particular phase get 100%value then it shows green color each phase has max value is 100%,simply show the progress bar for all  phases
Is it possible using bar graph in birt?
Is there another way to achieve this  scenario?
Thanks In Advance.
Regards
Amruta.
  • Hi Amruta,
    This is certainly possibly using a stacked bar chart. It would take some formatting to get right, but the general concept is that you'd have the X-axis be your project name, Y-axis be the phase progress, and the Y series grouping be the phase of the project. I've attached an example that should demonstrate this. Though I took some assumptions with your data structure, so the approach might be slightly different for you.
    Hope this helps.
    Chad Montgomery
    Customer Support Engineer  |  Customer Support
    OpenText Corporation
  • Hello Chad,
    Thanks for quick response ,I am new for birt,
     report not opening in open source birt version version="3.2.21"
  • Apologies Amruta, I was using the professional designer and it slipped my mind. Here is an example using open source.
    Chad Montgomery
  • Thank u so much  :) Its really helpful for me
  • To achieve drilldown on the chart, the chart has to be created off a cube with hierarchies. Hope that helps
